jfanaselle »
https://forums.nicoclub.com/jfanaselle-u73887.html
Fri Nov 02, 2007 5:05 pm
I think double din is the way to go, since it looks so much cleaner installed in the dash. You may as well take advantage of all that space in the dash. I'm a huge fan of the AVIC-Z2 if you're looking for navigation. I think it's better to use the one with the hard drive because with the other units, you need to have a disc in the unit to view maps, which means you can't listen to a CD and use the navigation at the same time. It's quite a bit more expensive, but you can find them for around $1500 on eBay.
