alright D-man im gonna try and go through some of this stuff as best i can... Im not gonna go into a lot of detail on each one to spare your intelligence, but if you need specific help on any one i can provide that.
AlabamaDan wrote:Ok guys it's time for me to put alot of work and some $$ into my Q45. I've got about 145K on it. She's still looking pretty good and running ok. She's getting a little sluggish and just sounding old. She's also starting to leak a little here and there. She's starting to ride rough and by that I mean vibrations and stuff. So time to do something about it before it's too late.
Like most of you, I'm a big fan of the older Qs (mine's a 1994) and really feel like it's a classic. I've been pretty lucky and haven't really had to do much to her over the years since I bought her.
Here are the things I was thinking of doing and wanted your input. Most of these have been gathered as a result of developing the ultimate Q45 Maint Schedule. I think all these are DIY:
1 Changing Oil and Filter (of course),2 Changing the Power Steering Fluid3 Changing the Fuel Filter4 Changing the Air Filter5 Flush Transmission, Drop Pan, and Change Filter6 Replace Brake Fluid7 Fuel Rail Flush8 Use BG OIL CONDITIONER9 Flush and Replace Engine Coolant10 BG44K11 Replace Tires 12 Replace Belts and the Idler Pullies13 Clean Mass Air Filter14 Clean Trottle Body15 Lubricate Properler Shaft Grease (Heard about this, but what is it?)16 Replace Shocks and Struts
Additionally I know I need to inspect somethings and take action based upon what I find:
1 Inspect Brake pads, discs, drums, linings, lines, cables2 Inspect Drive Shaft Boots and Shaft3 Inspect EVAP Vapor Lines4 Inspect Exhaust System5 Inspect Steering and Suspension System6 Inspect the Underbody
These are little more advanced, but probably still DIY right?
1 Replace Thermostat 2 Change Spark Plugs (Big Job?!?)3 Replace Hoses4 Replace Fuel Pump5 Replace broken aftermarket antennea with OEM6 Install Transmission Cooler
Now these are a few things that probably need to be done, but probably need a trip to T3. What do y'all think?
1 Plemun Hose Replacement2 Replace Knock Sensors3 Replace Motor Mounts4 Replace O2 Sensors5 Replace Transmission Mounts6 Replace U-Joints (Driveshaft) 7 Replace Water Pump8 Replace Wheel Bearings9 Replace Valve Cover Gaskets
If I do all this, she should be in 100% new condition right? I'm looking to buy me a little Jeep Cherokee as a runabout and could park the Q while all this is underway.
I appreciate your comments and hopefully encouragement.
For jobs that are iffy, I will rate them on a scale of 1-5.
1- Easy lemon squeezy, no or few/simple tools, no experience needed2- Pretty easy, may need some tools, but still little know-how is needed3- Moderate, may take a few hours and some various tools, but still very doable with an afternoon and patience 4- Moderate, but may neeed more know-how and tools5- Something you never want to do again, either because its very tedious, labor intensive, and/or tools required.
1. OK2. No biggie, just suck out the old stuff with a turkey baster and replace it. Do this once a week for a month or so (youll probably go thru about 2 quarts of fluid in this time) and youll have brand new fresh fluid..... Then just replace whatever is in the resovoir everytime you change your oil and youll never worry about it.... Use ATF3. Easy, no explanation necessary, but use OEM.4. Same as 35. Not really hard, maybe a 2.5 on the scale... It would be a 1.5 or a 2 if you had a lift or a way to raise the car highish.6. Easy, just get a one man brake bleeder kit ($6 at autozone) and bleed each caliper.... You shouldnt even have to take the wheels off, but youll need to jack the car up.....7. about $100 at the dealer. be sure to tell them to use a higher than normal pressure part way through (around 50 PSI should do it) to blow all the crud out... Another alternative if you want to take the plenum off is to send then to deatche works and have them refurbish each injector to OEM new.8. OK, do yo umean using the BG quick clean or what?9. no biggie, good thing to do in conjunction with a Tstat change (which ill get to later).... Just drain/fill the radiator a few times and you should be all set....10. The dealer will put that in after the rail flush if thats what you decide to do.11. OK. In bama you shouldnt need dedicated winter tires, so i might suggest getting some 16 or 17in rims so you can get an adequate performance tire.12. Not hard, but you dont need to REPLACE The idler pullies, but rather have new bearings pressed in. NAPA carries said bearings and can press them in for you. Its like $15/pulley vs $100/pulley for OEM new. The pullies dont go bad, just the bearings. For a belt/pulley job, id say probably a 2 on the scale.13. OK14. OK, your best off to take it off, youll need a 6mm allen socket.15. You cant really do this.16. OK. You cant really replace shocks and struts because the car only has one or the other . New tokico blues all the way around... Its not a job i like DIYing due to the use of a spring compressor, you can rent them, but I prefer to spend $150 and have someone do it. ALL other suspension stuff I will do myself. You can even have someone put the old springs on the new shocks and then do the R/R yourself. Thats fine, and ive done that. be sure to get new mounts and boots with the purchase of the shocks.
moving on..... all that other stuff you listed 1-6 on the next list is all stuff that your already technically doing while your in doing all these things....
moving on again...
1. Tstat is an easy job, probably 2 on the scale and wont take you more than 20 mins to do it..2. Plugs are probably a 3 to 3.5 on the scale... its not hard per se, its just very tedious and time consuming. Ive done it 3 times now and i still cant get it done under 4.5 hours... if your car has TCS it will add more time on the drivers side because theres a lot of crap to move out of the way.... Its a good DIY project, but plan an afternoon just for the plugs.3. Hoses are gonna be covered under the plenum hose thing...4. Probably a 3 on the scale, not really too bad to replace it. Have charcoal on hand to absorb the gas smell.5. Easy, probably a 2 on the scale, hardest part is taking the motor cover off and getting the old mast out... Other than that its realyl easy...6. transmission cooler is EASY.... 2 on the scale... Just be sure you have plenty of hose on hand, youll probably want at least 6 feet on hand. I think the B/M kit comes with like 4 feet and I was a little short... better to have extra. Bypass the stock cooler and filter all together (people will disagree, but thats what I recommend for simplicity. you will not decrease the life of your trans by taking the filter out).
Now onto the more complicated stuff.
1. Doing the plenum (with hoses, KS, and sending the injectors out for cleaning if you want) isnt too bad, its just very time consuming... If you factor out the time that it will probably take you, the actual work involved is probably like a 3 on the scale.... Its just things you need to keep track of and know how to follow diagrams.
2. the KS can be done at the same time, and proabbly only add 30 mins of labor once the plenum is off.
3. motor mounts can be done at home, but you probably dont have a way to support the engine from above....
4. o2 sensors are easy to replace, youll need both an o2 sensor socket and a 7/8 crows foot wrench (for the driver and passenger side, respectively). Do the drivers side from the top and the passenger side from the bottom. I can do the entire job in less than an hour. 3 on the scale because you have to go buy those tools, but as far as actual job its only a 2.
5. transmission mount is easy, 2 on the scale. you dont have to remove anything to get it out.. You just have to support the trans and you can do that with a floor jack.
6. the OEM driveshaft does not have replaceable U Joints. Any vibration your having, replace the transmission mount first and then go from there. 84 driveshafts dont go out too often.
7. water pump is easy, great time to do it is when you have the belts off. probably only adds 20 mins to the belt job.... 2 on the scale.
8. why do you want to replace your wheel bearings? No reason to replace them unless their making noise.
9. kind of a PAIN job... its not complicated, just a lot of stuff to mess with on the side of the engine. Once the coils are out its not too bad to pull the covers off, and teh gaskets arent too bad... you definitely want to combine this job with the spark plugs..... Id say its probably a 4 on the job to do both sides. But, after its all said and done, after you complete the job youll be glad you didnt pay someone $700 to do it.... its gonna probably be 4-5 hours per side. book time is 8 hours for both sides..... the spark plugs are no brainer to replace once you have the covers off, really doesnt add any time at all...
