One Crazy Max wrote:not to sound rude or anything, because im actually not being rude, and im looking forward to your results, but you dont have any power adders as yet. everything you listed frees up power that was restrained from the factory. a tune will just level out the power band and give your current setup a better a/f ratio compared to the pig rich stock map.
i have similar mods, except for the y-pipe. i intend on getting the y-pipe later this year, and at the same time im going to go with a full 3" exhaust from the y-pipe back, with no third cat. right now from the cat back i have a 3" into a 2.5" by the axle, and then back into two 3" mufflers, video for that is here http://www.youtube.com/watch?v=mV6fft3_hFY
i dont think you should be going with a 3" exhaust and back into 2.25". again, not to sound rude but, you kind of contradict yourself because you say 3" is best for optimal flow, and that 2.5" is too small for the VQ's displacement. i get that you might want to retain back pressure by going with smaller piping axle-back, but you mess up with the flow, and you will stifle the motor as you go higher into the powerband. and i know you've seen your dynograph, because you posted it up, i shows that the VQ makes power all the way to redline and doesnt really level off. with a tune, that graph will climb way beyond what you dyno'ed before.
anyway, i look forward to what youre gonna be getting done, cant wait to see. i will also post up pics and videos of my setup to come later this year.
AdamR wrote:One Crazy Max wrote:not to sound rude or anything, because im actually not being rude, and im looking forward to your results, but you dont have any power adders as yet. everything you listed frees up power that was restrained from the factory. a tune will just level out the power band and give your current setup a better a/f ratio compared to the pig rich stock map.
It splits into two 2.5" sections.
Also, backpressure wouldn't help things at all. That is a myth.
Either way, if you think that he will not gain power from a tune, you are mistaken.
Also, the power-adder thing is just semantics.
im not sure what you were reading, but im pretty sure you should read it again because i dont think you read it correctly.AdamR wrote:One Crazy Max wrote:not to sound rude or anything, because im actually not being rude, and im looking forward to your results, but you dont have any power adders as yet. everything you listed frees up power that was restrained from the factory. a tune will just level out the power band and give your current setup a better a/f ratio compared to the pig rich stock map.
It splits into two 2.5" sections. - ummm no. he did say it splits into two 2.25" @ the axle-back location.
Also, backpressure wouldn't help things at all. That is a myth. i never said back pressure would help anything. i said that he might want to retain back pressure, which would give him more throttle response down low, and stifle the motor up top.
Either way, if you think that he will not gain power from a tune, you are mistaken. i completely agree with you that he would gain power from a tune, never said he wouldn't. i said that with a tune the cars power band would keep climbing up top.
Yup the copied my rom! We waited 2 weeks and everything worked great!Hercman1 wrote:Aww man that sucks! Yeah, they had to download my ROM and send it off to UpRev first, before we did the tune. Once they responded and returned the "cracked" ROM, the shop called me in so we could Dyno and street tune. That blows man, I hope it works out!
Herc
Importroller wrote:!
Today was not a good day at the dyno. Uprev lied to me twice in two emails, and once to the tuner. I asked them to confirm they supported the 07 3.5 Altima & they assured me they do. Well, we hooked everything up, started the ROM download, and it froze. The ecu code is different for my car. We tried the ROM for the 08s, and my car took it, but then it wouldn't start. After a few minutes we got it running, but it wouldn't idle. So now we have to wait for Uprev to get back to us with a solution.
dldjros69 wrote:Yup the copied my rom! We waited 2 weeks and everything worked great!Hercman1 wrote:Aww man that sucks! Yeah, they had to download my ROM and send it off to UpRev first, before we did the tune. Once they responded and returned the "cracked" ROM, the shop called me in so we could Dyno and street tune. That blows man, I hope it works out!
Herc
The tuner helping you is trying to smooth it over... The ECU may accept it because it's in the same family, but the chips may be different in the ECU and the code may not be compatible. Basically there is a chip in in the ECU where this code is stored. Typically you could write ANYTHING you wanted to to this chip. If the right headers and footers are present in the file being flashed but the code is wrong or incompatible, it would flash fine but may damage the ECU or the engine itself when trying to start it.Importroller wrote:The tuner tried to do the other ECU code to see if it was compatible. Usually if it isn't, the ECU won't even accept the ROM, but for some reason mine took it. But it will all be fixed later this week
