Due to terrible sound from my old subs, due directly to the small cubic space of the g35 special fit enclosure, I've decided to upgrade a bit and thought I'd share.
I have this right now:
Those are twin Pioneer TS-W251R's stuffed in a box that only has .7 cu ft of internal space. Those subs require .7 min each. So they sound just awful right now. If anyone is looking for that box, I got mine on eBay:
http://search.ebay.com/_W0QQfg...stomsHe is currently out of stock, but you can find a similar box from Z-Enclosures:
http://stores.ebay.com/ZEnclosures
The amp was a Pioneer GM 5200T. Good amp for what those subs required.
Back to that .7cu ft of space. Very few subs can share that kind of space. After alot of searching and comparing, I found these Boston Acoustics:
http://www.crutchfield.com/App...p=111
They have good power and only require .5cu ft each. But of course .5 x 2 = 1, and I only have .7cuft. That's where the polly fill will come in. Throwing basic pillow stuffing in the box will make the subs act as if they have a bit more room. So I'm set there. Not a big Boston fan, but for the $, they will pound!
As for the amp, found a good sale on an Alpine M450:
http://www.crutchfield.com/App...p=115
Its got the power those subs need, and have an internal In-Line Adapter, which I need to run the input off of the rear speakers since I don't have an aftermarket head unit. It also only requires an 8 gauge power wire kit, which I already have installed.
After some negotiating with Crutchfield, I got the amp and subs for $344.97. $109.99 for each sub, $149.99 for the amp, free shipping and $25 off the total cause I'm awesome. It would have cost me $12 less via Amazon, but I get alot more service out of Crutchfield, and a 30 trial just in case.
I sold my old subs amp and box for $300 to a friend if I install it, so after everything I spent 45 bucks!!!! Go me.
Just thought I'd share that in case it helps anyone.
