qship96 wrote:255 thousand miles on an early q transmission is awesome! mind if I ask your maintenance secrets? if you added an auxillary cooler,and at what mileage?how often did you flush the fluid and what type did you use?
The transmission cooler was put on about 250K so the car went most of it's life without one. The Fluids were changed as per maint specs by previous owner. I don't believe she tore up and down the roads and I know from her and the dealer she used to go to that no transmission work was ever done besides reg. maint. Only the fuel pump was ever switched out. The drive shaft is origional and everything else has been done by me, myself and I. She runs so sweet you wouldn't believe me unless you saw the Odometer mileage.
I will be searching high and low to get a good deal without cheaping out. I totally believe these engines are invulnerable or industructable if properly maintained. transmission did pretty well too! Car is at the age where everything needs to be changed if I want to keep driving it and that's what I have been doing. I don't intend to stop.
Thanks rsiwicki, I'm trying to get up with him. Now how about that Rack & Pinion? Is that something I can do when I do the suspension conversion or should I say would it be easier to do the two at the same time? I'll call joe about the R&P tomorrow.
red
