Time for a new SR clutch, what should I do?
Cgeigert
Car: 1989 Nissan 240sx
I've had an Exedy clutch and Fidanza flywheel since the swap, about 20K miles at most. It's starting to slip since I turned up boost so time to change it out. Should I just get new friction surface and clutch disc and TOB or replace the whole clutch disc and pressure plate and everything? If I do replace I'm thinking Exedy stage 2.
simmode1
Car: Red '95 S14
Hmmm... does the White Bunny clutch fit SR's? I know it's mostly a KA favorite, but you might wanna look into that...
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
No, SR have a 240mm clutch to start off with.
Hijacker
Car: '92 240sx Convertible
'94 F-150
You're burning up a stage 1 clutch on a factory turbo with increased boost? Are you doing 5k clutch drops or something? I've git the exact sane setup in my rebuilt SR and have well over 40k miles with no slippage. The only abuse it sees is an occasional auto-x. Either you got a poor clutch pack or you've torn it up somehow.
As for a replacement, lots of people enjoy ACT clutches. A friend of mine runs a T28 hybrid on that clutch no problem. Avoid Spec. They're crap.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Call up Tennessee Clutch Supply and order one from him. There is some threads floating around and they seem to be holding up to a lot of abuse and you can't beat the price.
danshaz82
Hijacker wrote:Avoid Spec. They're crap.
just curious, what makes Spec crap? ive run one on my KA for a few years now with no issue, and from what i remember, Razi runs the same one on his KA-T with no issue as well. granted its a stage 2+ on a KA, but i was probably going to go with that when i go SR.
Hijacker
'94 F-150
Do some searching on Spec within the boards. I've seen a few horror stories over the years of Spec clutches just grenading way too easily way too early. Their after sale service used to be a nightmare, but I think that's been ironed out for the better. I'm sure that the quality of clutch has improved since I last remember keeping an eye on them, but the few spec discs I've had in hand weren't very well put together and coupled with some nasty reviews from back in the day, I've just always avoided them.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Exedy is definitely my favorite clutch manufacturer. Not sure what your budget is but i know my next clutch will be the Exedy Hyper Single. The stage 2 with a Fidanza flywheel would be my next choice.
Good luck!
danshaz82
Hijacker wrote:Do some searching on Spec within the boards. I've seen a few horror stories over the years of Spec clutches just grenading way too easily way too early. Their after sale service used to be a nightmare, but I think that's been ironed out for the better. I'm sure that the quality of clutch has improved since I last remember keeping an eye on them, but the few spec discs I've had in hand weren't very well put together and coupled with some nasty reviews from back in the day, I've just always avoided them.
fair enough. id have to take a closer look at mine when i take it off again. plus the only thing ive had to compare it to was a burnt OEM clutch. but ya learn something new every day
Razi
Car: Moo
Mine started making weird noises lately. :rotfl
Only happens on the first start and I have the clutch pressed in.
Still holds good though, and doesn't make noises when I'm driving.
Whenever this thing dies, I'll probably switch to a white bunny setup from Competition Clutch.
