time for a new clutch?
S13CoupeLuvr
Car: '93 240sx SR20 dark green hatch
'95 Maxima white 5spd
For the past few days I noticed my clutch was slipping more and more. Now when I try to move, every gear revs like its in neutral. Im guessing its time for a new clutch, which clutch is the best quality for the price? Also im going to be needing one that can hold over 400whp.
boost_creep
Car: 92 sr powered coupe,06 Spec V
i have the spec stage 3..it holds up to 360 ft. lbs of torque..but lemme tell ya...the pedal feels easier than stock..and the engagement is mint..very streetable too...just my two cents
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
Or you can buy the ACT 6 Puck clutch. Good for cars putting out over 400+WHP also can hold up to 463 ft/lbs of torque.
jdm240witsr
Car: RPS-13
the ACT 6 puck with heavy duty pressure plate will break your leg if its a daily driver. I HATE IT in traffic. Good thing is u can jus replace the disc over and over since the pressure plate is pretty solid.
SR20DETPoweredS14
jdm240witsr wrote:the ACT 6 puck with heavy duty pressure plate will break your leg if its a daily driver. I HATE IT in traffic. Good thing is u can jus replace the disc over and over since the pressure plate is pretty solid.
Good thing you said that considering I was planing on buying that clutch...looks like im gonna have to go search for another one thats just as good as the 6 Puck as long as it wont break my leg.
