some of the worst advice ive heard. ever. first of all, oil viscosity doesnt have anything to do with the size of the motor. besides, you shouldnt have to use any additives. i like to use ams oil with an amsoil filter. have you seen a fram filter cut open. its absolute shiet. wix is great too,they also make the carquest and napa filters.Mr.Sandman wrote:Always, and always go with Full Synthetic. Mobil 1 Full Syn. 5w30. And, also use Black Label bottle "Lucas" additive. You have a small block, dont need to go with thick oil. Some may say you should go with 10w30. Thats fine, though just 5w30 is just fine. I save 2 miles per gallon now with 5w30 vs 10w30. Engine doesn't have to struggle as much pushing the oil through the block.
Also, i use FRAM for my oil filter. Why, cuz they have a hand grips, so nice and easy to take on/off.
your such a fool, I'm not going to argue with you. I've corrected you too many times, and tired of it. Your just worthless, its such an important topic, that takes way to much time writing about. Enjoy your nice conventional oil, cuz you'll...wait you've already got me started..........fatboy wrote:some of the worst advice ive heard. ever. first of all, oil viscosity doesnt have anything to do with the size of the motor. besides, you shouldnt have to use any additives. i like to use ams oil with an amsoil filter. have you seen a fram filter cut open. its absolute shiet. wix is great too,they also make the carquest and napa filters.
that API rating has been superseded.read a s"better than SG".unit77 wrote:The owners manual specifies 5w30 and API Service SG...I have looked at AZ,Advanced etc and cant find anything with that API rating.....is that something that has 'evolved' to a newer rating?...thanks
Dont take this the wrong way, just tryin to help the man. Though, how are you going to educate someone by calling it "whole crapload of this stuff called Molybedum", and "bunch of other stuff". I like to use facts, so that it gives the viewers more confidents in what im talking about. Oryou know it all, just didn't feel like saying all the complicated factors that come in to play. i dont know, im just wonder. thats all.elphkotm wrote:The Valvoline MaxLife contains a whole crapload of this stuff called Molybedum (compared to standard oil formulations) that cushions piston rings and valve seals and a bunch of other stuff. Another thing to think about.
im sorry, enlighten me on times you've corrected me. teach me something mr.Mr.Sandman wrote:
You obviously have no concept of why a partiular oil is decided upon by the manufacturer and not only that but how the engines oil passages are created based on that decision. You are most certainly reducing oil flow with the thicker oil, not only that but your engine has to work harder to move that oil around. The most imprortant areas to lubricate are dependant on oil volume and pressure, both are crucial and very with temperature. Put, 5w30 in your motor and if you don't feel an improvement your no kind of driver. Take my word for it or not I couldn't care less but I guess the rest of us and the manufacturers have no idea what we are doing.
Do some research on synthetic before making such an ignorant statement. True if he has an oil leak and he's going to top it off it really doesn't matter because the oil life is not an issue it leaks out before it can break down. As for synthetic being overrated check this link. This is not the 70s, were not testing sh*t out.
