Time Control Unit
Kuno3x16
Car: CARS
I have a 1995 240sx...my signals don't work... i tested the combination flasher and it works fine... there seems to be no power going into my combination flasher for some reason... fuses are fine... anyone know what else i can check???
thanks =)
Modified by Kuno3x16 at 2:35 AM 11/19/2005
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
turn signals always have a turn signal relay along with a fuse. also check your bulbs just to be sure. if those turns out to be fine, get back to me. you may simply have crappy Nissan wiring.
Kuno3x16
Car: CARS
My blinkers work... cause when i push my hazard button they flash... so since they flash i'm thinking my comination flasher is fine also...
95lstegman
the relay may or may not be the same for blinkers and for hazards. just check it. BTW, you haven't checked the FSM for the actual wiring diagram and neither have i (mine is mysteriously missing . . .), but that would be a good next step.
