Tilt/Telescoping Steering
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
NausetLight
Car: 2008 Infiniti EX35
Hi,
Has anyone had any issues with the steering wheel tilt feature not working? mine does not work and makes a grinding sound when i try to move it. the telescoping still works fine.
thanks
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
Check this old thread out >>> post4744719.html
You may still qualify for this Repair.
Welcome to the Forum.
NausetLight
thank you!
atlanta11
NausetLight wrote:Hi,
thanks
Unfortunately this is a Nissan weak spot. Tons of issues with the tilt wheel in Maxima's as well. I personally had the one in my Maxima repaired at the dealer and that board is filled with people who had the motors replaced
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
looking at the service records for my EX, it looks like the previous owner took it back 3 times for the tilt/telescoping issue and had the motor replaced twice.
I have had it for almost a year now and have never had any problem or 'bad' noise. (hoping I didn't just jinx myself) I don't use the feature to move it when I turn the engine off or turn it on...but I do adjust it often while I drive.
Kenike
Car: EX AWD
I had to have mine fixed. It was under warranty. Maybe around two years ago, no problems since.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
