willmoodom »
https://forums.nicoclub.com/willmoodom-u155679.html
Thu Jan 19, 2012 1:09 pm
is there anyway to reset the sensor for tilt steering? 2 problems. 1st is i can only get half of full cycle to tilt up while car is idling or running but once the car is off it goes through its full motion. being im tall, i normally tilt the steering all the way up when entering and exiting the car while running. other wise its a bit uncomfortable trying slide in and then readjust myself once completely in the car. can this be reset or do i need a new sensor?
2nd issue is when i got the car, the tilt mechanism would adjust up when key removed and tilt down when key entered. no longer. started that recently. i tried the button on the side and it changes nothing. sensor or something else. the first issue, no full motion, has been like that sense i had the car. though it wasn't a problem because the key in and out function worked. now it doesn't.
