Tiida/Versa Key Reprograming
Ryan-H
Car: 2006 Nissan Tiida ST Sedan 6 speed
thinking of buying one of these http://cgi.ebay.com/ebaymotors...ories i want to know if i can reprogram it myself or if i have to get Nissan to do it? if so how much will it set me back
mitsevo3
Car: versa
hi, try below step by step, it may help you for it..
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch. 2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Ryan-H wrote:thinking of buying one of these http://cgi.ebay.com/ebaymotors...ories i want to know if i can reprogram it myself or if i have to get Nissan to do it? if so how much will it set me back
Ginsu
Car: White 2009 Versa SL Hatchback
""Item Description:You are bidding on a NISSAN REMOTE FLIP KEY CONVERSION CASE with a retractable flip out key. This unit will work with the remote years and model(s) listed in the auction title only.
With this case you simply swap the electronics from your current remote into this case. NO REMOTE PROGRAMMING IS REQUIRED as your remote is already coded to your vehicle. All you need to do is have your dealer or an auto locksmith (which we can refer you to in all major cities upon purchase) to pair the (installed) security chip with your vehicle. ""
This is just a hollow piece of plastic. And its ugly. And you will have to pay big bucks for your dealer to program the new security chip. Why are you thinking of buying it?
Ryan-H
i knew about the remote thing. i just wanted to know how to program the chip into the car, s*** i did not know it would cost me to program the security chip. will a auto locksmith be able to do it or void my warranty. I want the key because i am sick of the key fob banging against the dashboard and the key fob now falls apart if it hits the dashboard of i drop it. and i LOVE the switchblade keys.
