MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Wed Mar 21, 2007 7:30 am
The biggest difference is the bucktooth.On the Tiida, the tooth is a part of the bumper. On the Versa, it's a part of the grille.Also, the Tiida bucktooth is smaller, and there's a sort of hangover to it from the hood that the Versa hood does not have.
If you really wanted to use a Tiida grille, you would need to fill in that middle spot somehow.
There may also be a difference in height. Since the hoods are different, the Tiida grille may be taller (or shorter) which would mean it may need to be trimmed as well.
