TIIDACANARIAS »
https://forums.nicoclub.com/tiidacanarias-u141030.html
Tue Aug 18, 2009 1:50 pm
More specs:
Main features, safety and ecconomy Engine size: 1461 ccm (89.15 cubic inches) Fuel type: Diesel Fuel mixed driving: 5.2 litres/100 km (45.23 miles per gallon) Seats: 5 Drive: Front wheels Transmission: Manual, 6-speed Airbags: 6. Front airbags. Side airbags. Engine and transmission Engine location: Front, transverse Displacement: 1461 ccm (89.15 cubic inches) Engine type: Inline, 4 cylinder Max power: 106.00 PS (78 kW or 105 HP) at 4000 Rev. per min. Max torque: 240.00 Nm (24.5 kgf-m or 177.0 ft.lbs) at 2000 Rev. per min. Compression: 15.3:1 Bore x stroke: 76.0 x 80.5 mm (3.0 x 3.2 inches) Fuel system: Turbo Valves per cylinder: 2 Fuel control: Overhead cam (OHC) Cooling system: Liquid Gearbox: Manual, 6-speed Speed and acceleration Top speed: 186.0 km/h (115.6 mph) 0-100 km/h (0-62 mph): 11.3 seconds Power/weight ratio: 0.0763 PS/kg Exterior and interior Chassis type: Hatchback Max no. of doors: 5 Passenger space: 2520 litres (666 gallons) Cargo space: 310 litres (82 gallons) Optional cargo space: 425 litres (112 gallons) Steering, brakes and tires Steering: Traction control. Electronic stabilasation program (ESP). Brake details: Antilocking brake system (ABS). Front tire dimensions: 195/65-R15 Rear tire dimensions: 195/65-R15 Dimensions and weight Weight: 1389 kg (3,062.2 pounds) Max weight with load: 1785 kg (3,935.3 pounds) Towing weight: 1100 kg (2,425.1 pounds) Overall length: 4310 mm (169.7 inches) Overall width: 1700 mm (66.9 inches) Overall height: 1540 mm (60.6 inches) Wheelbase: 2600 mm (102.4 inches) Fuel capacity: 52.0 litres (13.74 gallons)
I forgot to add to equipment remote audio and cruis control in steering wheel, rain and light sensor -automatic-....
