one ton garage »
https://forums.nicoclub.com/one-ton-garage-u17338.html
Sat Jan 06, 2007 5:01 pm
If you're hearing a metallic clunking sound when turning or going over a big bump, it's also possibly coming from the spring settling into the spring cups (usually on the strut housing). Sometimes the spring could move a little bit upon reinstallation, so the end of the spring isn't settled perfectly into the notch in the spring cup, and you'll hear the clunking a few times before it seats perfectly again. If it's way off, then you'll need to take it off and reinstall, but as long as the spring is made for the car, it shouldn't be causing a problem, and if the noise persists, there might be something else to blame. I personally would recommend cutting the bumpstop either way once you lower the car that much. It doesn't hurt to cut it down, as long as you leave at least 1-1.5" of it remaining to prevent bottoming out the strut.
