Tieing up loose ends on wiring... Need help. RB25DET/S13
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
RB25DETI've been through the search and i've been through my FSM, but i just get either A. ConfusedB. Or its not very clear info, so im sorry Kamin if its here and i missed it or something.
As the title suggest i am in need of some help here as im almost done with my RB25 project, Now.... I had my wiring done with the wiring specialists so the upper wiring harness was done, but not the lower one.
So at this point and time, my fuel pump is working, and my doors and everything dings and my interior lights, and head/tail lights work.
So heres the deal, right now im just trying to get the starter to click and get the motor to crank before i really fire it up so the motor gets lubricated.
With the clutch depressed the ACC relay and another relay which im not familiar with.... i also have all of the 6 connectors dissconnected.
This ACC clicks This one clicks, i dont know which one that is, anyone?
And these are the 6 undone connectors. Now if im not mistaken 2 for the A/C system, and 4 are for the lower harness one starter and three others for the speed, neutral and reverse switch.
What wires was it that i needed to splice bla bla, and or should i just use the LOWER KA harness.... If so where should i put the two knock sensors and where should the oil pressure sending unit wires go? Should i just exchange connectors from the KA harness and wire up the other connector from the RB lower harness?
Thanks in return if you guys know.
integra7
Car: 1995 Nissan 240sx
here you go....use the KA lower harness
Kansei240sx
Thanks for the help man, i appreciate it time a million.
