Tie Rods
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
Chaz1956
Car: 2014 Infiniti Q50 Premium AWD (VIN JN1BV7ARXEM696269)
I am in a bit of a quandary. I'm trying to buy new tie rods for the front of a 2014 Infiniti Q50 Premium AWD (inner and outer). Several sites have different parts for the cars with DAS (Direct Adaptive Steering) as opposed to those with hydraulic steering. I'm getting conflicting information from different Infiniti dealers as to whether or not this particular car has DAS. Does it matter? Are the tie rods the same on a Q50 with DAS and a Q50 with hydraulic steering?
The VIN is JN1BV7ARXEM696269, if that helps.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Not sure why anybody's parts department would have trouble with that, the database only shows one set of original and one set of supersessions for your VIN:
RH Outer:
Original - D8520-4GA0A
Superseded By - D8520-6HL0A
LH Outer:
Original - D8640-4GA0A
Superseded By - D8640-6HL0A
RH/LH Inner:
D8521-4GA0A
No Supersession
VStar650CL
Technical Expert
PS - The parts for DAS versus non-DAS are different, but your VIN indicates you have DAS.
Return to “Infiniti Q50 / Q60 Forum”
