Tie rod spacer dimension?
zcar93na
Car: 1993 300zx 2+0 N/A 5-speed
1984 W150 Ram (Getting a Cummins swap)
1984 Isuzu P'up diesel(sold)
Hi guys, I got my car to a buddies shop and we're almost done with it. I'm replacing my inner and outer tie rods and figured while I had them off, I'd install some slip-on spacers. The trouble is, I can't find anywhere to buy them. If I knew the exact dimensions I could make some out of tubing. Any help is greatly appreciated, Thanks.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Have you looked into adjustables? What is your end result goal?
zcar93na
I want to increase my steering angle for tighter turns in everyday driving. Also I would like to have the extra angle for countersteer when I decide to get it sideways. I've done some more research and the spacers don't need to be any thicker than 6-7mm (~¼"). I done some measuring; .625" i.d, .920" o.d by ¼" thick. Stopped by the local Tractor Supply and they have steel bushings .625" i.d, .875" o.d by 1"long for less than $2. I'm thinking of cutting my own. What do think?
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Personally, I'm not a fan of rigging a performance car. Don't get me wrong, there are a lot of things I don't mind going MacGuyver on, but a car like this I don't. I think it's well worth the investment to go adjustable.
You aren't one of those Hellaflush guys huh?
zcar93na
What do you mean hellaflush? lol
If I see a way to make just as good quality of a part at the fraction of a cost, I will. I have enough mechanical sense and fabrication skills to do so. I posted an update in my build thread with a picture of the spacers. I first cut them .480" wide, but done some research and seen they had to be .250" MAX. So I cut them down and they fit like a dream. I done this on a lathe so they're symmetrical.
But Adjustable spacers? I'm lost on this ziggy, i haven't seen them
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Not adjustable spacers, adjustable suspension components.
And hellaflush is when you have mad camber
zcar93na
I cannot stand camber queens, these have plenty of camber from factory. Adjustable suspension is in the plans, but right now my main concern is getting the car driveable.
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
:dblthumb:
ArticDragon192
Car: 91 Z32 2+2
Those spacers are nothing close to being rigged at all. It's a common modification. Powered By Max in San Diego usually has theirs in stock. Also SPL sells the Tein spacers. But if you can make your own, more power to you.
