Tie Rod removal 280Z
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Jaymanb8379
Car: 1977 280z
I need to replace both outer tie rods on my 77 280Z. The jamb nut on the passenger side does not want to come free. First of all I want to make totally sure I am attempting to turn the nut in the proper direction. On the passenger side, the inner (jamb nut) is what I am talking about. I am attempting to turn the nut to the right. Is this correct? my assumption is the driver side should be turned to the left?
Thanks
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Look at the treads. You can see the direction you need to turn. Also soak it with PB blaster before attempting.
Jaymanb8379
Car: 1977 280z
My assumptions were correct, the passenger side is turned to the right, the driver side you turn to the left. I ended up pulling the entire rack assembly out of the car, I was so far along it didn't make sense to not go the extra mile and replace all the bushings.
Return to “Datsun Z Forum”
