tie rod questions..
1990q45er
I'm about to replace the front outer tie rod on the passenger side and (possible) the driver's. Do you have to take out the rack to do it? it doesn't look like it, but just making sure...
another thing: while I was disconnecting the TR from the tires, I had to smack it with a hammer a LOT to get out. Anyway, the thread is kind've ****ed up now and I can't get the nut to screw on anymore. I guess it doesn't matter for the passenger side since I'm getting new outer TR for it anyway, but does anyone know of a cheap way I can fix the driver's side one? or do I just have to bite the bullet and buy a new outer TR for the driver's side too? Thanks!
Raxephon
Car: '04 RX8...for the moment...
1990q45er wrote:I'm about to replace the front outer tie rod on the passenger side and (possible) the driver's. Do you have to take out the rack to do it? it doesn't look like it, but just making sure...
No. Rack removal is not necessary for replacement of outer tie rods.
1990q45er wrote:...but does anyone know of a cheap way I can fix the driver's side one?
If the threads aren't too far gone, you can use a dremel and a cutting disc to carefully clean up the threads. Its easy to screw up so you have to take it slowly and patiently.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Get a metric die to clean the threads correctly.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
maxnix wrote:Get a metric die to clean the threads correctly.
UNless you have hands like a surgeon, I WOULD NOT use a dremel on threads, you will likely make it worse, so bad that you may not even be able to fix it with a die...
1990q45er
I guess I do have surgeon hands, cuz the dremel method worked perfectly .
Out of curiosity though, what is a metric dye? i haven't heard of that before...
Modified by 1990q45er at 7:36 PM 4/22/2006
elwesso
2007 BMW M Coupe
1990q45er wrote:I guess I do have surgeon hands, cuz the dremel method worked perfectly .
Good. I get nervous with that kind of stuff.
You're familiar with tap/die sets right? Taps cut new threads on fastners, dies bore new threads in metal..... A metric die is simply a die in a metric size
Raxephon
Glad to hear it.
Maxnix is right in the normally correct way being with a die.
But an inexperienced person can screw up with a die as well.(Incorrect angle, Incorrect size, etc...)
Both the dremel and the tap/die method requires a steady hand, a good eye, and patience.
elwesso
2007 BMW M Coupe
I just prefer whenever I mess something up to make an excuse to buy new tools
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
I have used hand file to clean up threads and If hard to fix use a hacksaw to cut off bad threads! Save yourself all the trouble next time and use a Tie Rod Fork tool like you suppose to for TR removal.
Raxephon
PopPop wrote: I have used hand file to clean up threads and If hard to fix use a hacksaw to cut off bad threads! Save yourself all the trouble next time and use a Tie Rod Fork tool like you suppose to for TR removal.
You don't have to use a tie rod fork either.
You can remove it the same way G20 owners typically remove theirs.
If you tap the side of the spindle where the outer tie rod mounts with a hammer (On the spindle, not the tie rod), it should pop right out.
elwesso
2007 BMW M Coupe
in this case I would dedicate another nut the same size so you can put a nut on there and not damage anything.
Raxephon
elwesso wrote:in this case I would dedicate another nut the same size so you can put a nut on there and not damage anything.
No, you don't tap the tie rod at all, just the section that it slides through on the side.
EDIT:You have to loosen the tie tod nut before you do this though.
elwesso
2007 BMW M Coupe
anlasak wrote:No, you don't tap the tie rod at all, just the section that it slides through on the side.
I know. What im saying is put a nut on the top so you can wack at the nut and it wont matter if you damage the nut, and you wont damage the threads on the tie rod.
