chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Thu Feb 05, 2004 4:36 am
hmm lets see. in theory it should be a simple job but **** always comes up. when i was doing mine, i had trouble getting the stock lock plate off the inner end and ended up ripping it off, which wasnt necessary heh. if it gets stuck or somthing just bang on the stock junk with a hammer, it should come loose. And to get the stock inner ends off, i used a crescent wrench and got under the car and pushed the wrench, bracing myself on the front lower arm. the steering rack kindof torques when you do this because it is on so tight, dont worry you wont break anything, but it is on there TIGHT. took me about an hour but if you know how to do it it should take like 15-30 min.
