pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Mon Dec 27, 2004 10:02 am
well, the tie rods are in good shape, the tension rods have whiteline bushings installed but part of me thinks that they are loose, and the alignment is ok I just had it on the machine a couple weeks ago, I made sure that the toe is set at factory,and I believe the camber was at about 1 1/4 degrees but I cant remember now for sure. I part of me wants to think that it is not all the tie rod angle and that the tension rods are suspect, as soon as I get a chance I am going to go with pillowball tension rods because after raising it up I noticed that it didnt help much if any, but still if you were to get under one of these when they are lowered more than 2 inches (I noticed it when I pulled it on my drive-on lift at workto change my oil) that the tie rod angle is a bit excessive. the next time I can remember to bring my digital camera I will pull it on the lift and take a shot of it from underneath so you can see what I am talking about
