Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Sun Nov 02, 2003 3:36 pm
the tie rod (and tie rod end) is part of the steering, it connects the gear housing assembly to the LCA. the tie rod and tie rod end are the last two parts that directly connect the 'steering' to the 'wheel'.
the larger part of the tie rods you have pictured (lower pic, right side) goes to the inside, away from the tie rod end/wheel. the smaller end of the tie rod would screw into the red portion of the tie rod ends you have pictured. the black portion of those same tie rod ends would connect to the LCA. the silver nuts on the preformance tie rod end correspond to the crown nuts in that little baggy in the lower picture. they are crown nuts so a pin can be pushed through and secure the position of the nut on the tie rod end screw threads (there is a hole in the screw of the tie rod end).
the aftermarket end you have does look different in some places, almost looks adjustable, or maybe is set to pivot in a way to deal with geometry differences from lowering?
