captainluigi »
https://forums.nicoclub.com/captainluigi-u34023.html
Sun Dec 28, 2008 3:40 pm
If I understand,the screw sliding down and out would be the tie rod end?If so there are a couple of methods. Some more favored than others.
I choose to shoot a shot of white paint where the lock nut is then back off a 1/4 turn. Loosen the castle nut atop the T.R.. a few turns. Now smack soundly with a 2# maul. Now remove the castle nut. Now unscrew the T.R.E. Now the lock nut., tape the threaded portion of inner T.R.E. apply grease and slide the new boot on. Assemble as follows. Put the O ring on the boot. Thread T.R.E. lock nut on to previous point, screw T.R.E. to previous point. Install in spindle, torque to spec. Tighten lock nut to spec Remember the wire tie securing the new boot. 1 hr. tops.Go to the alignment store and buy one.
