Boy oh boy where to begin?
TimTurboZ wrote:So I already have steering angle spacers from an order I made from PBM awhile back. Best inexpensive and legit option seems to be buying Z32 inners from napa/kragen *like $30 cheaper than SPL rapes you for* and either getting stock S14 ends or aftermarket.
I gladly paid to be "raped" when I bought mine from SPL all at once, I'd rather have OEM over some cheap third party, even if it works just fine. It's piece of mind. You sound like you're on a strict budget though.
TimTurboZ wrote:Just wondering of decent and inexpensive tie rod end choices. Is the about $90 the Tein ends cost the lowest price but best quality I can get?, because megan and circuit sport appear to be the same cost. Is it worth it to get the aftermarket ends? I can get s14 ends new for $20 each or used cheap
Is your car lowered at all? Will it ever be lowered? If the answer is yes, don't buy the Tein outers. It's practically a 100% stock replacement, no adjustability whatsoever, no added thickness. It is SO worth buying aftermarket ends.
TimTurboZ wrote:Figure stonger tie rods and angle spacers will be enough of an improvement and aftermarket ends prolly wont be life changing to my drifting limits...
Aftermarket ends will be extremely, extremely life changing if your car is lowered. It's the biggest difference I've felt with tie rods.
Tie rods I've had:
-Stock
-Tein inner/outer with spacer for angle
-Tein Z33 inner rods with spacer/SPL outer rods (current)
I can't even express what a night and day difference the adjustable bump steer makes.
The spacer gives you a lot of extra angle, it's well worth it. I'm sure it would come in handy for drifting but I've never done that before so I can't relate. I just know it makes daily driving amazing, my turn radius is incredible.
