Tie Bar question?
That1Guy
Car: 240SX s13 Fastback
Noob here!I just bought a megan racing tie bar and it seems a little too short. The Guy i bought it from say it was for his 240sx coupe. Its their a different from coupe and fastback/ hatchback? I have a 1990 model.
Gabes13
Car: rb20det s13
what's a tie bar?
That1Guy
"The rear lower Sub frame brace eliminates rear sub frame flex due to extreme cornering." I just copy that somewhere. Its just like rear strut. But basically it goes under the car instead of inside the trunk.
Razi
Car: Moo
Coupe and Hatch subframes are all the same.So, the brace's length should be the same for both cars.
This is where it mounts, just fyi.
Gabes13
Car: rb20det s13
Interesting.I've always heard it referred to as a "diff Brace".
That1Guy
Did you have to remove anything and throw away any scrap metal or was it just bolt-on?
adrianfromthecastle
Car: 1992 Nissan 240sx
That1Guy wrote:Did you have to remove anything and throw away any scrap metal or was it just bolt-on?
its all bolt on. I think the only thing different needed to do is get longer hardware because with the tie bar in, the oe bolts would be too short. Hopefully it was provided by megan or something. My tie bar came with longer hardware.
isn't the megan one adjustable anyways?
That1Guy
Yeah it is adjustable but its just looks short. I'm pretty sure it will fit.
adrianfromthecastle
That1Guy wrote:Yeah it is adjustable but its just looks short. I'm pretty sure it will fit.
so you haven't even tried it yet?
That1Guy
I put the car on a lift and had 3 people with me eye balling it and we came to the conclusion that it might be too short. I want to do some do some research before i put it on instead in trial and error.
ashibah83
Car: 93 SUPA BLACK COUPE
i have one installed on my car, make sure the suspension is NOT compressed, so basically put it on with all 4 wheels off the ground, it should fit by extending the brace to make it longer, mine was kinda a pita but it did fit
Razi
Car: Moo
If it's adjustable....adjust it so it's longer.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
Razi wrote:If it's adjustable....adjust it so it's longer.
good, i wasn't the only one thinking that.
op, are you sure it's megan? i can't find an adjustable subframe brace from them, unless maybe it's an old design.
94_240sx
Car: 94_240SX
OE bolts work just fine. I saw positron_ has this bar, so I bought it on eBay. It was $9.99 or $11.99 shipped somethinglike that. I don't think 240s need it.
Chris28
Car: 92 s13 KA-T
numbnuts240 wrote:op, are you sure it's megan? i can't find an adjustable subframe brace from them, unless maybe it's an old design.
Megan adjustable subframe brace. Excuse the dirt, this is right after I purchased the car.
numbnuts240
2011 Ford Focus
2010 Mazda 3
must be an older version, it loos like all the new ones aren't adjustable. and judging by your pic, i'm thinking that the op doesn't have the black brackets on either end.
adrianfromthecastle
94_240sx wrote: I don't think 240s need it.
I felt zero difference... but who knows?
sounds like a civic part that a 240 owner thought would be a good idea to use... kinda like c pillar bars, lol
Chris28
Car: 92 s13 KA-T
I'm 95% sure it's only purpose is to make changing the diff that much harder. It basically covers the 2 lower bolts.
