While this is not my engine, the valve train noise in the YouTube is so similar to noise that mine currently making.
So before you view the video, I know the first question will be about oil pressure. I just finished measuring it. I initially thought the noise might be due to low oil pressure.
Oil – Mobil1 – 0w40.
Warm engine oil pressure
FSM Oil Pressure Test
Idle – 675 RPM - 20 PSI
Run - 3,000 RPM - 75 PSI
Here's the video with the similar HLA noise.
[youtube]http://www.youtube.com/watch?v=ripuVvms ... re=related[/youtube]
Background Information
1) Noise developed after installing new timing chain guides last fall.
2) Car did not run for 3 months while changing guides and other parts.
3) Engine was turned over by hand several times to locate TDC and to test the new guides. Most likely the HLAs filled with air and dried out during the guide job.
4) Oil pump chain and gear were replaced along with guides.
5) FSM guidelines for oil pump chain to guide clearance followed.
6) Previous owner changed oil every 2,500 miles (old school I know)
7) Noise seems to be around the driver side bank.
8) Front main seal that was replaced last fall has failed. It leaks a significant amount of oil now.
Pictures of the engine are below.
While I’m puzzled about the HLA noise, I will be going into the engine again to replace the front main seal.
Any suggestions will be greatly appreciated
