Ticking Temp. Sensor
93jdirty'
Car: 1993 Infiniti J30
While Im on the Highway ( constant speed say above 55) My temp needle starts flickering, now it still about in the middle of the bars the whole time but it flickers a couple of mm's. Anyone know what this is? Thanks`
gr8scott72
Car: 1994 Infiniti J30t
93jdirty’ wrote:While Im on the Highway ( constant speed say above 55) My temp needle starts flickering, now it still about in the middle of the bars the whole time but it flickers a couple of mm's. Anyone know what this is? Thanks`
Maybe the sending unit going bad?
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO. How long since you've replaced your thermostat?
Also check your coolant reservoir to make sure your car is not consuming 'more' coolant.
93jdirty'
can you tell me where the sending unit is and is the thermostat a PITA job?
gr8scott72
93jdirty’ wrote:can you tell me where the sending unit is and is the thermostat a PITA job?
No and yes.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
IF you havent done your timing belt recently and it needs done, you might as well do the entire belt job.
