Ticking
ph34r
My KA24DE ticks like crazy! My Dad says it's the lifters but im not sure. I already removed my upper chain guide(which was broken). This week I'm gooing to do the seafoam treatment and see if that helps. Has anyone had the same problems? How do you fix this?
lilvtboigotrice
Car: 93' 240sx Hatchback SE
where exactly are you hearing the tickling from?
corn322
Car: 1993 240sx
might just be the injectors, they're pretty loud
ph34r
it's coming from under the valve cover pretty sure it's not the injectors though( unless there dirty)
nissilvat
Car: 1990 240sx
what the prob might be is your lifters. just add engine oil treatment. get the can that works for 4 cylinder vehicles. its called "restore" engine treatment. that should take care of it. u can get it at walmart
ph34r
thanx. ill post up once ive run some retore through.
