Street1 »
https://forums.nicoclub.com/street1-u131110.html
Thu Jun 04, 2009 9:29 am
96' nissan maxima. Some of you have helped me with issues prior and i just want to say thank you. The clutch is fine and the car is running smooth. But all the sudden i have a ticking noise comeing from my motor. I immediately assumed a cracked head. So i let the car cool down opened the radiator cap started it up and had no air bubbles nor smoke ran smooth. So i opened the oil cap and looked in. Now i can't remember the name of this peice but if you open the oil cap you will see a bar spinning i believe comeing from the cam or connecting to the heads. That bar is not spinning in a complete circular motion is seems slightly off balance. I thought that is a possiblity of the noice but due to the heads may not be moveing in the right order causeing the noice not sure. To my knoledge it's not suppossed to seem off set it's suppossed to move circular without any off tilts. Any ideas would be great. Also i put in 10w-30 oil when i changed my oil filter but it seems it's too thick because under that spinning bar it's not spitting out enough oil unless i really give it gas. What is the right weight to put into the 96. Might have that question answered sooner because i may go pick up some more oil if i get time today. Sorry for the long post i appreciate all the help in advance.
