ticking sound... valve adjustment?
Fenvy
Car: 2005 350Z Base 6MT
i heard ticking from the motor this motor, I heard similar ticks before on my b18b1 and it was fixed with valve ajdustment....
the ka has hydralic valves or something according to the search button, what about sr20det?
I didn't mis-shift or anything like that, sometimes I Drive it a little hard but that's all
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
This is common with SR's but we don't need valve adjustments from what I believe.
Nismo_Freak
Car: 89 Nissan 240SX
Loveless wrote:i heard ticking from the motor this motor, I heard similar ticks before on my b18b1 and it was fixed with valve ajdustment....
The lash is hydraulic which means... no adjustment. More than likely just a small blockage of the lifter hole.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
or,you might have got some air in some of the lifters.try bleeding the air out and see if that stops the sound.
Fenvy
how do I bleed it
180fan
Car: 89 fastback
pull the lash adjuster out, put it in a tub of oil and use a thin metal rod to press down on the ball that's up in the top of the lash adjuster. Depress the top and keep doing it till the air bubbles are gone. Keep em pointed upwards or in the tub of oil on their side.
mynismo
you sure its not the injectors? hehe.. sounds dumb but i just had a friend look over my car because i heard a fairly loud ticking coming from it, and its definitely the injectors pulsing.
