i can pretty much garauntee that its not a bent rod. but i have no othe idea what it could be. the car runs so smooth, but the ticking is just so irritating. it doesnt affect the performance.nrmskate wrote:It could be multiple things, the worst would probably be bent rods...
But, it could be something else pretty simple.
i am using castrol GTX 10w-40xekushnr wrote:Make sure your oil level is fine. Sounds to me like a stuck valve due to a frozen rocker. Change your oil, maybe put a little on the rocker arms under the valve cover and run it for a bit to let it soak in.
it is a DOHC. how hard is it to adjust the bucket lifters with shims? how would i do it?Rucca wrote:I assume this ticking noise sounds kind of like a poorly maintained sewing machine....
SOHC? Just the noise of the hydraulic lifters not fully pumping up. Pretty normal on a high mileage KAE - no simple fix.
DOHC? Excess valve clearance. Only adjustable with shims on the bucket lifters.
Sound more like a bunch of marbles swirling around a can?
Timing chain is loose and needs new tensioners (should replace all timing chain components) or needs the upper guides removed.
is it called just lucas motor oil?? i have lucas gear oil? is that the same thing? but i have never put any of it in the engine, i guess i could try it?nrmskate wrote:For oil I also use the Castrol, but through a quart of some Lucas in there.
Its supposed to be REALLY efficient.
Hey! You might want to turn caps lock off!azn_b110 wrote:LOL HEY U MIGHT WANT TO OPEN UR VALVE COVER AND REMOVE THE TIMING CHAIN GUARD THAT IS HOLD BY TWO BOLTS ON THE TOP U WON'T MISS THAT PEICE TAKE IT OUT BEFORE IT FINALLY BREAKS OFF INTO THE ENGINE. ASAP DON'T HESITATE GOOD LUCK
Don't need the micrometer. Just a feeler gauge. To get the shims out without removing the cam is a PITA I have heard if you don't have the tool.Rucca wrote:It isn't really hard to adjust the shims but it is time consuming and not something I'd recommend a novice do. Also, you need a micrometer (pricey) and feeler gauges. It is outlined in the FSM.
Basically remove valve cover and measure the gaps between cam and lifter. Any of the gaps that are larger than spec you note. The spec is .012 - .015 inches with engine hot. So, for example, if you found a gap of .019 inches you would need to add .07 - .04 inches of material to that lifter to bring it into spec. Remove the cam, remove the lifter, remove the current shim and measure. If the current shim was .15 inches, then add .07, result is .22 so you would order a .22 inch shim for that lifter.
The full procedure is under Engine Mechanical starting on page 28 in the service manual. Actually reading it I see that you don't need to remove the cam
How do you measure the currently installed shim without a micrometer?alkemyst wrote:Don't need the micrometer. Just a feeler gauge.
what would i use to get rid of sticky valves?Felipe wrote:sticky valves?
how would i know if i had to replace the timing chain guides?XMSducksauce wrote:Pop your valve cover off and check your timing chain guides.
