Ticking noise under intake manifold
Neejay
I thought the ticking noise was my timing chain/guides, and later thought it was my injectors. But theres a ticking noise thats coming from under my intake manifold.
Is there something that normally makes a noise under there or is there something that commonly goes bad or wrong there?
I got a ka24e (sohc).
navysnail
hydraulic lifters or timing chain if it isnt the injectors. zerothread?id=61002 read 4 posts down, that is how to check the lifters.
Neejay
240kid wrote:hydraulic lifters or timing chain if it isnt the injectors. zerothread?id=61002 read 4 posts down, that is how to check the lifters.
hmm...I'll double check tomorrow and make sure the sound is coming from under there. Thanks for the heads up. I'll update tomorrow.
Riley2.4L
Car: 1995 240sx SE (S14)
I have a '95 and am having the same problems. Should I just try the same procedure?
