Well I don't know if this is gonna help you out.
Here is the ticking my pathfinder was making.
https://www.youtube.com/watch?v=_EQ4ejwP8hk
It wasn't an easy job but I did an extensive tear down to find the culprit. It turned out that ALL of my exhaust valve clearances were out of spec. I needed to replace 7 lifter buckets to get them back in spec. To do this a lot of stuff including exhaust cams had to come off. Since another culprit could have been the timing chain i decided to swap that while I tore it down. Several of the chain guides were very worn. enough where it was clear that the chain was at least potentially rattling around between the plastic guides.
4 weekends later. I got it all buttoned up and it runs like a freakin champ now. Zero ticks.
Now If I could just figure out why the damn rear main seal is leaking after replacing it and all the oil pan gaskets... I'd have what runs/drives like a brand new truck.
