ticking noise ? help...
beans33
Car: 1993 ca18det 240sx
well after putting the ca in a couple of days ago everything has been really good. Now when i start the car there is a ticking noise, it sounds like its coming from the front timing cover. The noise is kinda random. Stared doin a couple days ago and then would go away, now it does it when I start the car and has not went away since. Some people said it might be the water pump or lifters. Im just curious. Please let me know what you think. thanks again.....
djmace
lol i have the same problems...either the injectors cycling or what i believe is the lifters sticking...
beans33
Is there anything that can be done to eliminate that or atleast qiuet it down some ? just wondering thanks
boost_boy
beans33 wrote: well after putting the ca in a couple of days ago everything has been really good. Now when i start the car there is a ticking noise, it sounds like its coming from the front timing cover. The noise is kinda random. Stared doin a couple days ago and then would go away, now it does it when I start the car and has not went away since. Some people said it might be the water pump or lifters. Im just curious. Please let me know what you think. thanks again.....
If you didn't change your water pump before you installed the motorset, then my guess is that is the water pump.
Dee
fraz
Car: rb30det gts4
vh45 g130
Yea, what he said.A new water pump is cheap and easy to do, so you might as well do it.
CA/VG/RB lifters are bulletproof. SOmetimes they get blocked up wth crap and rattle. You can try an engine flush, but im not a fan of that.I would take the lifters out and flush them out with solvent, fill them back up with clean oil and slap them back in.
I have done this a few times and seen it done many more, and it has always worked a treat
F3600
Hey can you write up a litlle "how-to" toremove the lifter and reinstall them ? i never did that and i would not like to Break something .. ill look in my fsm to see if there some writeup about that
thx
beans33
yea a write up would be nice but thanks for the help..
djmace
yes i agree a write up... ok illl start:
1: Remove Valve Covers...
