grendel »
https://forums.nicoclub.com/grendel-u9658.html
Wed Sep 15, 2004 3:48 am
ok, i replaced the timing chain on my ka24e at 113k miles. somehow it had jumped a tooth with the previous owner. i checked the head and there was no damage to the valves, which is good. after its all reassembled i have a verry lound tapping sound from the valve cover. it sounds like lifters. the other thing that makes me think that is when i take off the oil filler cap the idle will drop real low and sometimes even die. you can hear a lot of air being pushed out the opening. im not sure if i should suspect a faulty rocker thats sticking or if i may have put the timing chain back together with 1 tooth still off. any ideas?
