kool-aid54 »
https://forums.nicoclub.com/kool-aid54-u10011.html
Fri Jul 16, 2004 5:22 am
no, it does it whether I'm in neutral or driving along. And why does my car cut off when I take it to 5000 rpms when redline is 6000rpms, is it a cut-off?
Thanks for all the help so far, if I figure this out I will definately share the info. I'm going to put in a quart of that engine cleaning stuff called " Gunk motor flush" its suppose to flush and clean your motor in five minutes. I bought it from Autozone, the boss told me to use that stuff instead of transmission fluid. I might still later use transmission fluid. After I put in the "Gunk" and give my car an oil change I'm going to put in a quart of "Marvels Mystery Oil" along with with the new batch of motor oil. Hopefully that will create a little light at the end of the tunnel. If that doesn't work I'm going to take the valve cover off and check the rockers and valve clearance. I need to try to fix this before the 24th of July because there is a drift event in South Bend IN at the Tire Rack and I really would like to take my car and participate.
Thanks man I appreciate all the helpChris Goshen IN
