Ticking injectors...
konatown
Car: 1994 Infiniti Q45t
2010 Genesis Coupe
Thought I had a case of these. Could here a clicking noise above the engine noise with the windows down, absolutely awful.
Well I went to go pull my drive belts and the damned PS/Fan pulley needs to be replaced, the bearing is dried out and ticks.Thank god I guess!
Q451990
That's an unusual failure mode for those. Usually they whine like a Ford power steering pump. In either case it's a good thing you found it. More than one Q has overheated after that pulley seized and the water pump stopped turning.
Heath
DrewQ45
Car: 1990 Infiniti Q45
I'm gonna replace all my pulleys soon. When converting my AC, the compressor pulley wasn't as smooth as some. I think I'll go aftermarket with these.
...Drew....
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
TexasOil provides alternatives
I keep a stock of the Q45 idler pulley bearings now. I have 3 cars that use them. I no longer use Timken -had bad experiences lately. I use extremely high quality parts with synthetic grease for ultra-wide temperature range. These are made in the same facility and production lines that make the super-quiet bearings used in nuclear submarines and in space equipment.
I will sell a set of 4 for $25, including USPS mailing. Paypal only.
Same size bearings ( but far inferior quality) cost $20 EACH at parts stores now.
konatown
2010 Genesis Coupe
texasoil wrote:TexasOil provides alternatives
The parts stores in my area carry virtually nothing besides airfilters and drive belts for the Q45 because there isn't an Infiniti dealership within 2 hours =(
Check your email, texasOil!
DrewQ45
I'll buy a set. Never took notice... are the bearings easy to get on/off the pulley wheel?
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Pretty sure they need to be pressed out and in. You can buy a press or take them to a shop
DrewQ45
Texasoil...
Tell me how to make payment... you can send me an e-mail.
NyRider
Car: 1997 Infiniti Q45
TexasOil can those same Bearings be used for a 97 q45 if so Count me in. Do you ship to Rochester NY 14621
E-mail me at [email protected]
MCovington
Car: 1995 Q45
I just took one of these ideler pulleys off the other day and I could not get the bearing out of the metal casing. The bearing is pressed in and then it is crimped in place so it will not come apart.
