ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri May 23, 2008 12:09 pm
By where you say the sounds are coming from and the symptoms, I would hope one of your flywheel or pressure plate bolts didn't back out. I've had a friend in the DSM world that just couldn't ever keep his flywheel bolts on for some reason. The sound it made was kind of like a "ting" that changes occurance with different rpm. It is either that or I hope you have an awesome multi-plate clutch setup. Multi-plate clutches usually only do their ticking/dinging when the clutch is fully depressed though. When they are engaged, they become silent.
