deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Feb 19, 2005 3:06 pm
The main rocker/lifter oiling that comes thru the center bearing cap/tower is prone to clogging. Usually the block portion of the passage itself clogs as it is smaller diameter. You can try shoving some thin straight wire down that center passage in your head, wiggling it around trying to get as far down as possible. I have seen this to be much more common on Z series engines but the causes are same. Usually when a nissan/datsun is in the shop with this problem, the end result is pulling the head and/or engine replacing. I have only been able to fix one Z24 this way, along with some compressed air.
It could be something else, but i highly doubt it. Do you have any sort of debris in your oil? Plastic chip/dust perhaps?
