Tick tick tick
HijackTheLeft
Car: '90 240sx coupe
I just bought a 1990 240sx over the weekend, and I've noticed a slight ticking sound. It gets louder and faster when I accelerate, and it only starts after I've been a little hard on the car. It's definately not a knocking sound, just a tick. Does anybody know what that might be??
ArcherV20
Car: 1995 240SX
Yeeeep - most likely the Timing chain guides. Looking at a good 5 hours of work ahead of you and getting your hands a little dirty.
But if it's a marble in a rattle can sounding noise that can be heard while your car is even sitting still, then this guide will fix it completely..
zerothread?id=105618
HijackTheLeft
not really a marble in a rattle can sound, just a tick that increases in speed and volume with the rpms... even when i'm sitting still.
ArcherV20
Car: 1995 240SX
That's it - in anycase you're going to want to remove these guides for future reference. So try this - if it doesn't work report back and we'll take it from there.
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
Maybe fuel injectors? Try and see where it is coming from. Its common for injectors to click.
ricebike
2002 Quest
2005 Altima
can be an exhaust leak...@ the manifold-block
get a mech w/ a trained ear to confirm.
xekushnr
Car: '90 Nissan 240SX Hatch
could also be a frozen rocker arm. check your oil level, add a bit if its a little low. run the engine for a minute or two and then cut it and let it sit for a while. it has happened to my 240 before and once i got back in the car to drive the rocker arm had unseized. good luck.
benemorius
Car: s13, s13, eg, e36
There are several things that can cause ticking. It seems like I've become a tick nazi lately so I'm gonna give it a bit of a rest. Just search the forum and you should find plenty of basic info on different ticking noises. I will say that if you could describe it as more of a tap and less of a rattle, and especially if it occurs after it's been driven hard, it could be your valve lifters. (damn I sure say that a lot) Perhaps you are a bit low on oil, or perhaps it is so dirty that it is having a hard time making it up to the head.
