santa109 wrote:Since the sound goes away when the engines turning a little more, could it be that oil pressure builds up and that the tensionneers on the chain are activated by oil pressure (or so I've heard?). Then maybe only the tensionneers need to be replaced?
That's a reasonable assumption. The tensioners are operated by oil pressure, and as you rev up the engine, oil pressure increases. If you have a weak tensioner and your chain is in decent shape, you could get away with just a ~$60 tensioner.
I guess the key is to try to isolate where the noise is coming from. If its coming from the upper chain guide area and not from lower in your engine, then you should have a pretty easy time removing the two upper guides and replacing a tensioner.
I'm having the same problem with my '93 240SX. I'm going to start off by checking my oil pressure this weekend and if that is within spec, I'm going to see if I can find out where the chain is hitting. If it's the lower chain, well...that's gonna suck.
