Tial WG
boost infested
Car: cars, chicks, food, and .....
So i put a Tial wastegate with a 4.5psi spring in my car tonight................ and the gauge shows 4.5psi! The spring tension between the tial and deltagate is night and day diff'. i dont think deltagates are that bad. i just didnt know what rate of spring is in mine. i am going to get a 4.5lbs spring for the deltagate next week and i will post the result between tial and delta.
should i get a higher rate spring than 4.5? how high can i go with a 4.5 spring and a EVC? i want somewhere between 10-12psi.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
4.5 spring should be just fine...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
But as I found out...even with a decent boost controller, the WG will crack open with that light of a spring. Part throttle boost in my car SUCKED with the ~4.35psi spring, and I changed to a 7psi spring (still set at 9psi overall), and the response difference was AMAZING.
So use a stiffer spring, like 7-8psi, then a boost controller to get the last 3psi...or just get the proper WG spring and use no boost controller. That gave me the best response overall.
New TiAL springs are $25, might as well...
- Brian
huguetpj
Car: 93 KAT Coupe
:: orion :: wrote:But as I found out...even with a decent boost controller, the WG will crack open with that light of a spring. Part throttle boost in my car SUCKED with the ~4.35psi spring
Was this with an electronic or manual boost controller? What do you mean by sucked? I don't seem to be having issues running 7-9PSI with my Tial 35mm WG with the 4.35PSi spring. Just curious.
