Unnatural »
https://forums.nicoclub.com/unnatural-u8349.html
Wed Jul 02, 2003 7:33 am
Agreed...a T25/28's doesn't really flow enough at 7-12psi to make good use of an external wastegate. I'm a fan of overkill but you got to draw the line somewhere. However, if this is an upgraded turbo we are talking about that MAY change things.
Between the 38mm and the 40mm wastegate...as stated above the larger wastegate with control larger turbos at higher boost levels with less change of boost spikes.~Brendan
