"Thunk" when engine starts. Bad motor mount?
amaff
Car: 2003 Nissan Pathfinder SE
I believe I've got a busted engine mount. Is this a common failure on these?
I'm getting a pretty significant "thunk" right as the engine cranks. Is there a 'usual suspect' that tends to go out on these? It looks like there's 5 mounting points for the engine, per the FSM, and I'd like to not have to pull all of them one at a time to see which one's on the way out (assuming that's what it is).
That said: maybe they all make that sound and it's nothing to worry about...
Thoughts?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Have a buddy start the truck while you stick your head, and ears, under the hood.
I can't remember anybody here busting a motor mount.
00QX4
Car: 2000 Infiniti QX4
Interesting subject...my qx4, when in "AUTO" 4x4, will clunk when I shut the car off. Maybe it could be transfer case?
01silvapathy
Car: 2001 Pathfinder LE 3.5
00QX4 wrote:Interesting subject...my qx4, when in "AUTO" 4x4, will clunk when I shut the car off. Maybe it could be transfer case?
Thats pretty common, its just the driveline going slack after the motor is turned off.
