thumping up front
CusCo_S14
Car: 95 240SX se
Well I just installed front z32 26mm calipers, slotted rotors and steelbraided brake lines front and rear . I was breaking them in when I heard a thumping noise up front pass. side could it be from my LCA bushings or something else.
BTW you can hear it when I do hard stops.
Modified by CusCo_S14 at 2:55 PM 8/18/2007
sleepersilvia92
Car: 1993 240sx coupe s1 rb25det,1989 hatch sr20det
i have the same problem any ideas?
ebfogg
Car: 89 240sx coupe
did you check the bolts for the caliper they may be loose and causing the thump when braking
