Thumping sound/rough riding
krill69
Car: 08 versa sl black 6 speed
Just started to get a wierd thumping/vibrating feel from the back of my versa. It feels like the back tires are flat(both have right amount of air in). I have no idea what it could be, will be bringing it into the dealer as it is only 1 month old. just wondering if anyone else has had this problem?????
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
Square tires? The cold'll do it. If the problem disappears after a k or 2 that's it.
KimberKenobi
Car: the Camel
Most people fill their tires more in the winter (since cold makes even air molecules pull together)
you may want to talk to your dealer about that... I don't remember what the winter pressure is that the dealership uses on the Camel...
krill69
The problem is it dosen't go away and I've also tried filling the tires more..
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
You sure it isn't square tires? According to South Park, Canadian cars have square tires.
frankoV
BBISHOPPCM wrote:You sure it isn't square tires? According to South Park, Canadian cars have square tires.
A little behind the times, my friend
frankohabs wrote:Square tires? The cold'll do it.
Can you believe that SP is right? Fact is, when it gets cold enough for long enough, the bottom of a tire flattens due to the weight of the parked vehicle, and then freezes flat. Once you drive for a bit the tire warms up and "rounds out".
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
Someone else on here had an experience with their car shaking and wobbling really bad at highway speeds recently and it turned out to be ice frozen onto the inside of the wheels I believe. Maybe check that?
Almost everytime you experience shaking or wobbling, its caused by a wheel being out of balance somehow, whether it's from a flat spot on the tire (from locking up the brakes), throwing a weight, or something foreign being on the wheel/tire (ice, rock, etc).
krill69
I forgot to say that when I went on a trip the noise and roughness went away at highway speeds. Then it would start up again when I hit towns and had to go slower....That's what makes it even more confusing to me....
frankoV
Don't have an answer/haven't had a problem [crosses fingers] but shaking my head looking at your gas mileage. otoh, it's Winnipeg in winter.'Nuff said [boy I don't miss it].
