AxiOn419 »
https://forums.nicoclub.com/axion419-u32499.html
Mon Dec 03, 2007 6:42 pm
OK, finalized everything with the rb20 swap this weekend and now have some kinks to work out. Right now, my major concern is this thumping noise I am getting when driving. I will give as much info as possible:
Car: 1991 s13 hicas w/ rb20
-Thumping noise is especially noticeable when starting off in 1st gear and accelerating, but the noise persist when in other gears.
-Once at cruising speeds, I do not really notice it, drives pretty smooth.
-When I hit a bump in the road, I think the bump noise can be heard even more, as if something is hitting the underside of the car from hitting a bump in the road.
-Its the same feeling you would get with a loose exhaust system hitting the underside of the car but I have pretty much jumped on the tailpipe and can not get it to reproduce the noise.
-I think the noise is more prominent when accelerating and taking a sharp turn.
-Does NOT make the thumping noise when stopped.
If I had to guess I would say the noise is coming from the rear center or rear passenger side.
Things I have done:-Checked exhaust system, it does have 1 broken hanger that I am going to replace but I do not think this is the issue as the exhaust system is very sturdy. Also, the noise seems way to developed when starting in 1st for it to be a shaky exhaust.-Had someone lay on the road and look under the car as I drove off, did not see anything out of place, yet it was still making the noise.-I do not have my shift boot on at this point so I can see the tail end of the transmission, it looks fairly stable, nothing out of the ordinary.
Could it be?:
-Universal joint?-Carrier bearing?
How do I test this?
As a side note, when working on the engine swap, I had jacked the car up by the differential in order to get under the car. While it was jacked up I heard a slight "pop" sound, it could have been the car "settling" (like an old house you know! ) but can not be for sure. I have slid under the car and looked for anything out of place or anything that could be broken but I just dont see it.
Sorry for the lengthy post, just trying to provide as much info as possible.
Thanks in advance!
