chad1200 wrote:sounds like you were hitting some odd shifting points. i hear/feel that same thing every now and then.
i have an 04 AT sedan with same problem as you CDNG35. down shifting in manual mode from 3rd to 2nd is a VERY hard shift. so hard i'll only do it now if the car is under 2500 rpms (or lower).
i've also noticed that if i only use my brakes to slow down in manual mode (and not down shift) my transmission goes from 3rd to 1st and never displays hitting 2nd.
I was told that it has occured in the sedan but they hadn't heard of this in the coupe. Hopefully I'll be making my last stop into the garage with this issue next week and that it's a matter of a small adjustment in the sensor.
Hope you get it resolved.good luck!
