Throwout bearing spinning on fork
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
T45
Car: King Kong powered Z32
Not a VH but there is a tremendous amount of Nissan specific knowledge here so...
2K frontier and the throwout bearing housing is spinning on the fork, allowing the fork to slip off the pad, get cockeyed and the clutch won't disengage. From memory I cannot recall what keeps the bearing from spinning, I thought it was the spring. Any thoughts?
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
yeah there is a spring/wire thing that holds it all together! without it, it probably wont stay put!
T45
The spring is in there...do they wear out? We are thinking of cutting an access hole in drivers side of trans and replacing it, think it's possible?
tempestas
well... you can't change the bearing or hub that way, trans has to be out. The spring holds it in place, but the hub is kinda machined square so it can turn. Either, the spring broke and the fork slid back far enough for it to spin... or the fork spread.... or a million other things. Its a truck, pull the transmission, shouldn't take but a couple hours. If the bearing is bad you will have to pull, hacking up the transmission would be silly.
T45
Wish it were that easy. Pulling the Z trans is easy, truck is 4wd and you have to pull the torsion rods and x member, and it sits on 35's so we need a giant jack and trans cradle, it's a pita. Thanks for the input, we may just pull the trans to make sure we aren't wasting time.
Return to “VH45DE / VK45DE / VK56DE Forum”
